8 & 16 ohm taps at the same time
  • 8 & 16 ohm taps at the same time
    I had a question asked of me today that I didn't have a clear answer for...
    "can you use the 8 & 16 ohm taps at the same time without damaging the OT?"
    I wondered how the impedance would be reflected with the two loads and wouldn't the 8 ohm tap see more current, assuming that it is a tap and not a separate winding.
    Anybody care to help on the theory?
    Thanks,
    Marc
    You can use them both at the same time, provided you connect a 32 ohm load to the 16 tap and a 16 ohm load to the 8 tap.
      I am thinking that connecting a 32 ohm load to the 16 tap and a 16 ohm load to the 8 tap is correct.
      I was wondering what the logic is for concluding this. Please explain.
      -Bryan
        The idea is that the transformer is still functioning acceptably if the transfomer losses are no more than they would be in the one-winding case and the power transferred from the tubes is no more than the one-winding case.
        Steve made the guess that if you load each winding to twice resistance, you get half power in each. The power delivered to a load from a transformer is
        P = V^2/R
        so if R goes to 2R, then power delivered goes to half.
