Attenuator circuit tone alteration?
  • Attenuator circuit tone alteration?
    Found this circuit scribbled down somewhere or other & interested in trying it but I've a question for all my mighty tube amp guru friends on here... will this thing squash my highs & could it be improved with a "bright" bypass cap incorporated somewhere? Many thanks y'all for looking!
    25 Watt Power Attenuator pg 1 with Values.pdf
    Hey you... Yeah you kid... Ya wanna buy some "Magic Beans"?
    [ATTACH]14992[/ATTACH]
    It will
    Here is one of my own attenuators wich is "tone-friendly"
    http://farm6.static.flickr.com/5219/...9092a65c_b.jpg
    As you can see, it's meant for low volume use, as the minimal attenuation is about 12 db.
    Looks like that : http://farm6.static.flickr.com/5096/...7115b560_b.jpg
    You can of course build a more powerful one :
    http://farm6.static.flickr.com/5052/...9ab4dcb7_b.jpg
    http://farm6.static.flickr.com/5133/...02b838aa_b.jpg
    Not exactly the same, this one is a 16 ohms one.
      Thanks kleuch, I'd like to see your values for the larger version. Seems like it works almost like a passive crossover in which case it would also be helpful to see the math so I could play around with slopes & frequencies.
        More like that : Click image for larger version
          There’s not a lot of maths.
          Resistors are here to help dissipate the whole power, and to limit the bright cap's efficiency -if you find the right cap you don't even need a switch to turn it off- you can calculate the cap, but with an 8 or 16 ohms SPKR, good values are around 5 - 10 µf, best is to try and choose the best for you use.
          Chokes are here to help maintain an inductance seen by the amp, speaker are between 200 and 600 µH.
            Another one : Click image for larger version
              I've built a few that are roughly based on the TW Airbrake. I use the large Ohmite wirewound resistors and add taps as needed. I use generic L-pad calculators on the web to calculate 3dB steps and usually end up with 0, -3, -6, -9, -12 and -15 steps while keeping the load reflected to the amp exactly at 4, 8 or 16 ohms depending on the build. Sometimes I'll tack a non-polar cap from one terminal to another to make it brighter as you increase the attenuation. I've found the "bedroom" setting to be pretty useless in the past. Everyone I've built one for really likes them and thinks they sound really natural. I have a THD hotplate and I'd say each one has their strengths. The hotplate gives more tonal control but it doesn't sound quite as natural as the airbrake to my ear. On the other hand the airbrake type designs tend to get overly dark sounding.
              I have several l-pads like those shown above but I haven't tried them. Any small low powered amp should be pretty forgiving of impedance mismatch so all of the above designs look usable to me!
              Last winter I built a tiny single ended amp and I intended to mount a pad inside the chassis as a "master volume" but I never finished it. I really need to though- should be a lot of fun once it's working. All of my amps are really too loud for indoor practice and this would help.
              jamie
                Update : http://farm7.static.flickr.com/6072/...34b76504_b.jpg
                casinolevant levant casino
