I need to locate the "raw bias supply" in order to install a power scaling kit.
""Raw" bias is the value of the supply at the first filter cap and prior to regulation. This voltage should be fairly constant regardless of the loading, or not, of a bias-set network."
I attach a small part of the schematics.
At what point (A,B,C,D,E or F) should i solder the connection?
Should i cut any cables (except for the point at "BIAS" because the installation provide a new bias supply)
Please do not answer unless you are sure where it is!
Edde
Edde
