Need help to make simple Pentode amp
  • Need help to make simple Pentode amp
    Hi.
    I came across a build of an amp and have some gutted parts from an old radio which I would like to use for a similar build.
    Here is the one I've seen 50EH5 Single-Ended (SE) DIY Tube Amplifier Project but I dont nessecarily have to build that one.
    And the parts I have are as seen attached in the pic below:
    Power transformer (Ive written the values in volts measured between each pair of leads)
    Audio transformer
    A Pentode tube, a rectifier tube, pentode rf/if stage and a triode hexode
    + a bunch of components (resistors, caps, diodes, transistors and so on)
    I also have a multimeter, signal generator, oscilloscope, adjustable dc power supply and loads of time to spare.
    Any advice on what to do from here on would be greatly appreciated, assume I know nothing (which is true). Mostly I dont know how to use the audio transformer and how to mix low and high voltages, also I dont know which side of the big cap that is positive.
    Sincerely
    What is your tube compliment? And what do you plan to use the amp for?
      The tubes i have are:
      Pentode - EL41
      Full wave rectifier - EZ41
      Pentode rf/if stage - 6BA6
      Double diode triode - 6AT6
      Triode hexode - ECH41
      They have all been part of the same old radio/gramophoneplayer.
      It doesnt really matter what the amp does, anything that is possible really.. I'm doing this mostly to learn.
      It would be useful as a small headphone/line amp or a guitar amp or just to add tube dirt when recording.
      Thanx in advance.
        A compressor would be nice aswell =)
          The 6ab6 looks like an odd tube for most basic applications. The 6at6 looks odder (made that word up). Tube compressors are complicated circuits that would need a couple of valves to do. That adds layout complexity and heater requirements. An outboard compressor is the usual choice for this reason.
          The EL41 looks like a cool tube. 4.2W in class A. The EZ41 should be fine too. You could do a Champ type build very easily with the trannies you have by using a more common dual triode preamp tube like a 6sl7 or a 9pin 12a?7.
            The 6AT6 was used in the Tweed Fender Harvard, just the triode side.
            - Yogi Berra
              Thanx alot guys, Ill see if i can get a hold of some other tubes
