I would like to build a 5E3 clone.
I know that a power transformer with the secondary high voltage rated at 320-0-320
Volt (that is 640 Volt with center tap) 120 mA should do the job.
However I would like to use a transformer at 320 Volt without center tap.
Of course I will not use a vacuum tube rectifier but SS bridge rectifier instead,
by means four 1N4007.
I also will add a series power resistore to simulate the voltage drop of a vacuum
tube rectifier.
Question is:
what current rating must I have with 320 Volt no center tap?
120 mA or 240 mA?
I suppose I still should have 120 mA, can somebody confirm?
thanks n regards
benito_red
tube rectifier.
Question is:
120 mA or 240 mA?
thanks n regards
benito_red
