Hi all,
I'm currently (very slowly) building a bass amp based on a modified Sunn Model T schematic (The PI and power amp is basically identical), and I'd like to drive my current cab, which is a 2 Ohm 4x12. I'm having trouble finding an output transformer that will work with 4x 6550s pushing ~150W into 2 Ohms. The best I can find so far (without breaking the bank) is a Hammond 1650R, which is a 5K:4-8-16 OT rated for 100W, and I'm just considering running it as a 2.5K:2-4-8 OT at 150W.
I've seen people say that because those Hammond OTs are meant for HiFi, that you could push a bunch more power through them with minimal sacrifice to guitar, but would it be noticeable in a bass amp? Especially given the fact that I'm running with a load on the secondary which it wasn't designed for? Is there a much better option for only a bit more money?
Keep in mind that this thing will probably be run at or close to full power 90% of the time, if the way I abuse my 160W Peavey AlphaBass is any indication, so if it's really truly gonna be borderline, I should probably find something else.
Thanks in advance!
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
