Hi guys,
Could I get a topic rolling on big bottle power amps? I'm slightly confused about the best way to operate the screens on these things. The maths and what looks like a good idea in principle tells me I should be dropping the screens to the region of 300VDC for a 6550/KT88, which to say I'm probably looking at ~500VDC on the plates with a 5K primary for a pair means a using a huge dropping resistor.
Heres a crudely drawn load line using a 5K primary:
http://dl.dropbox.com/u/8802910/JJKT88.png
Using the method described by the valve wizard, this shoots for about 80W output as an estimate.
A bit of digging about leads me to think that most people dont do this and they run the screens hot. Is this advisable? A discussion on this elsewhere informed me that the old model-t ran the screens of 6550's at 500V which is well over spec (thanks slayed if you read this). What is a sensible number to be gunning for? Certainly dropping it to near 400VDC gives me a good voltage to use for the preamp too, although I might experiment with a UL tap which will complicate that a little.
Thoughts and opinions very much appreciated. This one has bugged me for quite some time!
