A short experiment was performed to see just what the impedance of a 12AX7 grid is when grid current is flowing.
The following setup was used. A JJ 12AX7 was used in a typical Fender preamp circuit with 100K plate load resistors and 1.5K cathode resistors. Grid leak resistors are 1 Meg. Only one side is driven, that side has a 33K grid stopper. A 100uF 16V cap bypasses the cathode on the driven side. A 10 Meg 10X scope probe is connected to the plate and another 10 Meg 10X probe connected to the signal side of the grid stopper. B+ of 300V and 6.3VAC are supplied by an old Heathkit power supply. The signal is the collector supply of a Tektronix 576 Curve Tracer set to AC mode. The center of the screen is zero volts at zero current. Vertical is current, horizontal is voltage. The deflection factors are noted by the readout to the right of the screen.
![](http://music-electronics-forum.com/attachments/39530d1466210697-mvc-028ed.gif)
MVC-028F.JPG shows an X-Y plot of the tube. Horizontal is 2V per division with the center graticule line as zero volts. Plus is to the right. The vertical is the plate voltage, the bottom graticule line is zero volts. At the left of the trace as the input reaches about -2.8V the tube is cutoff, the plate is at 300V. At the right portion of the trace at an input of about +1.6V grid current starts to flow and the tube starts to "saturate". Further increase in grid voltage make only a small decrease in plate voltage.
![](http://music-electronics-forum.com/attachments/39529d1466210697-mvc-029ed.gif)
MVC-029F.JPG shows the display on the curve tracer. The slight slope as the trace moves to the left is caused by the 1 Meg grid leak resistor and the 10 Meg scope probe. As the trace moves to the right at about +1.2V grid current begins and the trace moves up at a rate that is mostly determined by the 33K grid stopper resistor. MVC-030F.JPG is the same conditions but with different deflection factors.
![](http://music-electronics-forum.com/attachments/39528d1466210697-mvc-031ed.gif)
MVC-031F.JPG shows the Curve Tracer moved to the grid side of the grid stopper. Grid current shoots off the screen at 2V. There is so much grid current that the cathode cap has charged up to about 2V.
![](http://music-electronics-forum.com/attachments/39556d1466397233-mvc-032ed.gif )
MVC-032F.JPG shows the X-Y scope plot and you can see that the trace has shifted the the right and the plate can now be driven to a plate voltage of 30V. (MVC-033F.JPG shows even more drive and the plate voltage is down to the neighborhood of 10V.)
![](http://music-electronics-forum.com/attachments/39532d1466210760-mvc-034ed.gif)
MVC-034F.JPG shows that with enough drive, the grid current reaches 4mA at slightly less than +6V and doesn't show any signs of stopping. Taking delta V over delta I the grid impedance is about 533 ohms. Note that the cathode cap has charged up to about 3V.
http://music-electronics-forum.com/a...-mvc-028ed.gif
http://music-electronics-forum.com/a...-mvc-029ed.gif
http://music-electronics-forum.com/a...-mvc-031ed.gif
http://music-electronics-forum.com/a...-mvc-034ed.gif
[Missing images restored by Steve A. (moderator) 06/20/2016]
