I thought I'd mention- the Soldano schem posted above has a major error- the effect return triode and cathode follower are wired wrong- 100k resistor should be on the effect return triode, not the CF.
sorry, yes it'll be 4 gain stages, it may have been way back in one of the first posts...
i agree with the effects send/return, and this is also being left out of the layout.
i'll have to hunt down that book! thx
forgive my lack of terminology, im getting some but still more to learn.
are you talking about the 100k resistor between pins 6, 1, 7 of v3 on the avenger diagram?
also i believe this diagram excluded the effects loop, would this paly any part, or nothing to do with it?
or are you talking about the 100k resistor attached to v3 pin8?
should this be to pin 3 instead?
for now, i am keeping this amp fairly simple, no effects loop, but i certainly want to do another build closer to the slo100 circuit with more channels and an effects loop, but with a better effects loop (obviously)
that first cathode follower is very important to the distortion of the amp.
I completely agree-but I think the SLO circuit is problematic and much prefer the simpler adaptions like a Mesa Dual Rect circuit. I say set it up similar to the Mesa circuit and use a mosfet send after a pad and a single triode for recovery. This way you only need a total of four triodes.
i just reviews the avenger schems i got my hands on, and i only see one possibility for error.
if i understand pre tubes, they are 2 triodes in 1 bottle.
so i could attach a component to pin 8 or 3 for example. you'll have to confirm this for me,
but if i assign pins 8, 7, 6 to be v1A, and 3, 2, 1 to be on the B side, do i have to keep that consistant between the rest of the pre tubes? all the A sides must be the same pins, all the B sides as well? if this is the case, then according to the schem i have, this layout diagram is backwards on v3 compared to v1, and v2. is this what you are talking about imaradiostar? otherwise it seems to jive with the schem...
the only discrepency i found is there is supposed to be a 220k res following the 330k res and 22n cap comming off of v2B before it connects to v3A.
I routinely ignore the A/B side of triodes and wire them to make the layout I'm using simple; consistency is not necessary. I have built an Avenger preamp off of those schems (note the name of the poster where you got those schematics ), so I would adjust your layout to match the schematic.
Donīt entangle yourself with A and B which are just labels applied by you (not the tube manufacturer).
Point to remember is that pins 1/2/3 form one group, and 6/7/8 form another, do not mix elements from different groups.
Label them with any letter you fancy, donīt get carried away by it.
