I am adding an NFB presence/resonance circuit to an older PV ULTRA+, figured I'd just add the JSX circuit but wanted to use a Fender/SVT dual concentric pot to replace the odd C&K 7211 ON/ON/ON switch in the ULTRA
the resonance switch is absent from a few ULTRA schematics, so I tried to decode it:
![](https://lh4.googleusercontent.com/-V6Xi1FvkKaQ/TvatIyNWb9I/AAAAAAAADn0/E8If4TZOX8U/s800/Ultra%252520plus%252520res.jpg)
I think my read is correct MED and LOOSE have 87k and 330k respectively across the 4.7nF cap, while the TIGHT has just the series C11 (22uF) and R84 (68k) at the PI (not shown)
The JSX circuit:
![](https://lh4.googleusercontent.com/-g9XoY5AZa9Y/TuhGfGuHvuI/AAAAAAAADmI/SONqZUK_iWc/s800/jsx%252520PR%252520control.png)
uses a 1MA and 10KL but my pot has a 1MA/50KL, while I could put 2 x 6.25K resistors from the wiper to each leg and sort of get a 10k pot, what would I expect to hear from the 50k pot vs the 10K? Since the full 10k represents the MAX presence 50K would be even more presence right? maybe a bit shrill? Could I modify the 4.7nF cap to soften the presence?
The JSX circuit:
