I know I just made a topic prior to this, but this is an unrelated question. When you purposely bias a preamp stage hot or cold to get it to clip on one side or the other and then it's inverted would biasing on to clip the same side give a more even distortion signal? For example, (and I may have this backwards) if I were to bias a stage really cold to clip the top of the waveform, and then the signal was inverted would biasing the next stage (assuming it's a similarly designed stage of the same type of tube) give the same type of clipping on the other side of the waveform making a mostly symmetrical distortion? I am not even sure it would sound good to the ear, but I'm just curious from a design standpoint since I'm under the belief that generally hi gain amps are designed hot, cold, hot, cold...when if it seems that maybe they should be hot, hot, cold, cold or something like that.
I am aware that the plate and cathode give off signals of opposite polarity, so does the mean that if the signal came in to the grid and out of the cathode that the signal would never invert?
Sorry if these questions are a little hard to understand...I'm kind of having trouble finding the right way to ask them. If I need to elaborate I will try.
