LED Pilot Light.
  • LED Pilot Light.
    I bought the regular Fender jewel type light deal, but I don't have room for the whole assembly. But I can fit the jewel nut in there and make it work with an LED no problemo.
    What kind of current and voltage can these things handle? I don't know what kind of rating to select. It would be cool to run it off' the AC mains if I could.
    Check this out.
    Link: AC-LED
      I did exactly that on something last week. Works like a charm! I don't think I used the bleeder.
      Don't believe everything you think. Beware of Rottweiler. Search engines are free.
        Use a "backlight" LED or use a few from a cheap flashlight (maybe 3 in a triangle) so it will be bright enough to shine through the jewel.
          That leaves the LED circuits directly coupled to the mains.
          Add a diode in series to block reverse, and a series resistor to set current, and run the LED off the 6VAC you already have.
          Calculate the resistor for maybe 10ma through the LED.
            Yep....just use the heater voltage and a diode/current limiter. I had to do this recently on a little kit hi-fi amp I reworked for harp use.
            For use behind a jewel cover, i'd use either a non diffused red LED with either a clear lens or the "tinted" style with a pale coloring that you can still see thru. The jewel does the diffusing, so you want a "beamy" looking LED.
              you could use a Supertex LR8 as an offline regulator! works to 450v!
              casinolevant levant casino
