a simple question....
  • a simple question....
    I have a simple question for someone (s) to consider. If a 5Y3 rectifier is inserted without proper indexing into its socket what might be the residual damage?
    I purchased a Harmony H-304 from a music store a few years ago. It did not pass signal but hummed rather loudly. I have been working on it , off and on, for the past years. It is a single-ended amp with a single 6V6 output tube. It also uses a 6BF6 preamp tube and a 6AT6 driver. When I bought the amp, the 5Y3 rectifier had no index pin (it had been snapped off) and the tube was installed without regard for the proper indexing.
    Over the years I have been able to test the tubes, replace electrolytics and drifted resistors. I have been able to get it operable but the output was weak (compared to a Harmony H-304A I recently purchased).
    Since almost 100% of the passives have been replaced, is it possible that the mis-indexing of the 5Y3 did some damage to the output transformer? Thank you for your thoughts!
    Usually it just blows the tube or blows the fuse.
      Time for a new 5Y3, and some voltage readings?
      Don't believe everything you think. Beware of Rottweiler. Search engines are free.
        The aforementioned 5Y3 is long since gone. The owner of the store tried to persuade me that they were all made that way. I took the amp home and replaced it ASAP. The amp always sounded good but lacked volume. When I got the newer version (H-304A) I went through that amp and found it to be very similar. When I got the 304A up and running, it sounded much better than the 304. I checked voltages and they were almost identical. Finally, I touched the outer paper wrapping of the output transformer to see if it was getting hot and the amp began to buzz loudly. I shut it off and tried to check it again but it still hummed. the only thing I can attribute it to is that the OT was on the verge of shorting out and all it took was a touch. I replaced the OT with one from a Valve JR (5.2K primary/8ohm secondary) and the amp sounds every bit the equal of the later version. I have all the volume and a lot fuller tone with this donor OT.
        I guess now it is clear why I initially asked the question about a mis-indexed 5Y3 possibly causing an OT to fail. As I mentioned before, nearly all the resistors and all the caps have been replaced in my quest to track down the problem. I did not have any voltage discrepancies to warn me of an impending failure...only the weak output.
