As a member in this forum now for some time - but more reading than contributing - I want to share with you the results of my prototype of a Bass Power Amp created over the last month.
The target for the design was more than 250W, weight around 20Kg with housing, small size. Here in Germany I have found a company who is delivering customized toroidal transformers for power and output which is a prerequisit to reach the design goal.
Here are the results up to now, schematic and a picture is in the attachments:
For the power stage I have selected the GU50, they are reliable and cheap.
Power at 20Hz: 295W
Power at 5 KHz: 295W
Power at 20KHz: 200W
Weight without housing 15Kg, Size without housing: 53cm x 19cm x 19cm
Plate voltage at idle is around 950V, at full load around 850V. The operating mode up to now is AB, the next step is to evaluate AB2
Hans- Georg
Power at 20Hz: 295W
Hans- Georg
