I picked up an old vacuum tube amp that uses a 600v plate supply in the PA.
I heard that the OTs for such a high voltage can have more inductance (more turns) than for a lower voltage which can cause a loss of high frequency response.
I also heard there are special transformers to be used in situations like this to avoid losing the highs.
The infomation was on some website where the person was speaking in general terms without giving any specific examples or information.
I am wondering if I can find out info about the OT in my amp. I suppose I could remove the transformer, put a dummy load on the secondary, and measure the inductance of the primary?
I suppose I need to use the plate resistance along with the transformer inductance and other circuit component info to draw up an equivalent circuit of the output stage?
Then I can analyse what kind of filtering effect the final has on the freq response.
Seems a little complex but not too far out of reach, but of course I have never done this before, so I am hoping for a little help.
One other thing I was thinking. Maybe analyzing just the output stage is not enough. If the highs did drop there, I suppose they could be boosted in an earlier stage to make up for this. If this is the case, I am wondering if the sound would be good in a situation like this?
I plan to convert the amp into a guitar amp. It is an old Stromberg Carlson amp I think. Actually it is missing all the covers and stuff, so I am not sure what it is.
Thanks
Thanks
