I haven’t been on this site in quite a while. But to be honest I was never really an active poster. I got into DIY to build myself a bass preamp and that has taken me on a several year journey building tube amps and effects pedals. I’ve come full circle and am looking to design a new bass preamp for myself. I am a huge Leo-phile so most of my stuff has been Fender-ish in the past. I’m looking to go Ampeg-ish this time around.
I will be working on 2 broken V4’s in a week or so and if I can fix one I can keep the other! This has caused me to research the hell out of these amps. I’m really interested in the preamp design and I plan to make a scaled back version for myself. I do not have a schematic drawn yet but if you are familiar with it I plan to copy from the input to right before the phase inverter. I haven’t decided how I’m going to approach the active mid control yet but that is not really my concern at the moment. I have 2 other design problems I’ve been asking myself and I thought I would see what you guys have to say.
Design Query Number 1:
If you are familiar with these amps then you know that there is a buffer after the active mid that goes to a slave amp jack and then after that there is a final gain stage before the power amp. My initial thought was to remove the buffer since I won’t be needing an output before the final gain stage but then I thought about looking into reasons I may want to keep the buffer in that position. I don’t need another gain stage and I don’t want to waste a triode so leaving it as a unity gain buffer will keep me from having to deal with far too much gain. One thing I saw mentioned but I can’t seem to find it again is that having a buffer between gains stages can help to avoid blocking distortion (which can be a problem when dealing with bass guitar). Is there any truth to this? Any other benefits to having a buffer between gain stages (besides when needing one before a tone stack)?
Design Query Number 2:
Also, I’m looking to experiment with saturating an interstage transformer (or mic or output transformer used as an interstage transformer). What sort of specs should I look for to find a suitable transformer? Would I even be able to here it saturating? Will it sound good? I know some mic preamps are pushed hard to overdrive input transformers. I guess this would be easy to do with the voltages coming out of the tubes. Is there anything else to consider. Would this even work?
Thanks for reading!
Thanks for reading!
