This is my 1st SE design at least Cathode biased and have a freaky thing going on with the power supply. It's actually an exact replica of a Champ
except there is no tube rectifier. I'm using the CT to one winding of a 450-0-450 CT tranny rectified FWB 1N4007's. That goes to the exact topology of an AB764 Champ Design. The OT is a Mercury FTPO-5 SE and I'm using a 6V6GT tube. The problem is I'm getting 63 volts across the Cathode Resistor and the screen goes higher than the plate voltage. The plate voltage sits around 340 and the screen around 360. Anyone tell me whats going on. I've checked wiring and connections and can't find it and at the moment the load is off the preamp and still no change. What do you think ?
