I'm new to the whole SE thing and I'm probably looking at it with more of a p-p mentality. Is there a limit as to how high you can run the B+ comparative to a p-p amp? I've been messing with a SE EL34 'mini marshall' which I set up essentially like a JMP with fixed bias but the PT I had on hand to use is putting the plate voltage around 430V. This is perfect for the preamp as it is maintaining all the preamp voltages exactly where I would want them to be, and frankly I'm happy with the plate/screens being where they are BUT I'm a little confused as to what I should be doing with the bias. Single ended should be biased at 100%, correct? However, at this plate voltage into a 5K OT, I put the meter on the cathode to watch the bias and even when I set it to @ 70% at idle, it almost doubles when I crank the amp and hit it with a signal. So, 100% is obviously going to be a problem and the current certainly is not remaining approximately static under load. (Just for the moment, I'm not considering the screen current, although maybe I should and subtract that?) So if it's single ended but not running in class A, what IS it doing?
Just looking for some thoughts, advice etc. Anything!
