What would you do?
  • What would you do?
    My amp only has 4 and 8 ohm outputs. But, my cab is 16 ohm, which is a safe mismatch into the amps 8 ohm output. However, I could rewire the cab for 4 ohms for a correct match into the amps 4 ohm output. Or, I could get crazy and just buy new 8 ohm speakers to run at 8 ohms.
    SO, what would you do:
    Run the mismatch?
    Rewire the cab?
    Get new speakers to run 8 ohms?
    I'd rewire the cab. 8 into 16 isn't necessarily safe.
      you can pull output tube pairs and match the 16ohm impedance that way too
      http://music-electronics-forum.com/t18102/
        How do you know he has a 4 power tube amp?
          That is getting exotic and extreme.
          I agree with hasserl I would rewire the Cab.
          If it is an old closed cab like I bought, that is a good time to vacuum and clean all the speakers.
          That helps on the vibration and rattles.
          T
          Terry
            Thanks guys. With some searching, I found that I can do both 4 and 16 ohms with 2-cliff jacks. I need the cab to work with another amp at 16 ohms.
            This should do it. I'll omit the switch in this diagram.
            Speaker Loads and Wiring
              I have re-wired many of my cabs with a 4-16 switch. When the switch is up, it's 16 ohms. Some poeple swear that the all parallel option sounds better.
                I run an 8 ohm tap into a 16 ohm cab all of the time with the amp dimed. Never had a problem never gave it a second thought.
                  OK, then then offer the original poster an unlimited warranty
                  Bruce
                  Mission Amps
                  Denver, CO. 80022
                  www.missionamps.com
                  303-955-2412
                    Thanks fellas. I got it going. I F'ed up a couple times tho. At first, I wired up the jacks outside the cab with wires out of the left and right speaker holes, so I couldn't get the jacks in the cab..
                    Whatever... I got it together, and measured with an ohmeter. I know ohms isn't impedance, but it's close enough to verify a load, and mine checked out.
                    As far as the tone I'm getting, the 4 ohm has a more raw upper midrange, and the 16 ohm mismatch being a little on the furry side, with less detail. I'm digging the 4 ohm.
