The Ceriatone layouts have diodes in series with the rectifier plates, but they have a 0.01uF/3000V capacitor across the rectifier plates. I copied this, but now I'm worried about the cap shorting and taking out the PT. Is this a bad idea? Should I just have two of these caps in parallel with the diodes? I'm assuming this cap is there to reduce switching noise. Is a cap even needed with a fast diode?
Thank you!
Thank you!
