Using the voltages and cathode resistor values from this schematic as an example, http://www.schematicheaven.com/fende...a764_schem.pdf, how many watts do we rate the amp at.
At idle, the amp is dissipating 14.34 Watts, correct?
(342-21)*(21/470)=14.34
After reading the information at http://www.aikenamps.com/Why70percent.html, I assume that since he says dissipation in an SE amplifier is at maximum during idle and drops to about half at full output, we would rate the amp in our example at about 7 Watts. Is this correct. I've been working on tube amps for about three years now and have learned quite a bit, but I've never been sure about this issue.
Thanks,
Jag
