I'm working on a project where I'd like to have an isolated audio output. This is solely to break ground loops in connected mains powered equipment. I've got a preamp and a power amp for instance, I'd like to isolate the output of the preamp to break any signal/mains ground loops. I see a couple of ways to do this and have a couple of questions about some of the ways:
Now since I'm going to have a buffered output, something tells me that I have to pay attention to the details when selecting an isolation device to preserve the low impedance nature of the buffer, yes?
As always, thanks for any thoughts or considerations. Seems the deeper I go down the hole the more I see that needs to be considered.
- Transformer coupling. Looks like you can get 200Hz to 15kHz low powered audio transformers inexpensively enough, but the 200 to 15k bandwidth is kind of a bummer, I'd prefer something flatter, but I'm willing to experiment since these types of transformers are used in other guitar circuits.
- Capacitor coupling. If you couple the signal and ground of a stage do you break ground loops? I'm thinking "no" because while you are AC coupling the signal you are still AC coupling ground, so it's a moot point
- Optoisolators. In the industrial equipment I use (advanced mechanized welding power supplies), the I/O is isolated using optoisolators to keep welding round (hundreds of amps) away from signal and small motor grounds (2 amps tops). However, it seems because of ROHS, most optos are some composition of solid state devices inside and I'm not sure that would play with audio very well (thinking along the same lines as solid state relays, digital pots and the like).
- Something I'm not thinking about behind door number 4...?
