I almost piggy backed this on another/similar post but I decided against it..... (obviously).
I have some real space issues with a conversion, so I am trying to get the most from all the turrets available.
Instead of having a separate ground for Rk and Ck, and then lift the ground on the resistor to operate the Trem, can I have Ck and Rk all on the same turret and lift the ground for both components with the foot switch.
In the schem below. Is it OK to have the Cathode cap and resistor on the foot switch, just so I can put them on the same turret.?
Thank You
Thank You
