I searched this topic, but I think I am more confused now than before.
How DO you calculate the Ohm value needed for a given "dropping" resistor.?
I am using Two 6K6 power tubes in a P-P, fixed bias configuration.
I am using the PT and Pi Filter from the below schem for the Eico Sig Gen. The reservoir cap goes to the OT CT. The first cap after the choke goes to the screens.
Now I want to add another filter cap for a 6SL7 LTP Phase Inverter. How do I calculate the Ohm value of that resistor.? For that matter, what plate voltage (from what I have available) should I run the PI plates at.?
Then I will need Caps and resistors to feed B+ to a 6SL7 tremolo circuit that uses both triodes.
And I will need B+ for both triodes of another 6SL7. The first triode will see the main guitar input, then a Fender BF tone stack, then the second triode before it hits the PI.
I am thinking I will need another filter cap and dropping resistor for those two tubes as well. Perhaps I need an RC Filter for each tube.?
I know this is a lot of info. I am in process of learning the J-Schem program so I can make a schematic. In the mean time, I just have to try and explain it to you the best I can.
Thank You
Thank You
