Hi,
I need a simple FX loop for a tube preamp with -10dB/0dB switch In some of their latest amp Marshall are using this SS FX Loop:
Since a single LND150 can now be used for recovery stage I was wondering if I can use it as a virtual earth mixer with small amount of gain (overall output level from the tube preamp should be 0dB max so max gain will be -10dB->0dB). I "modified" this schematic in Photoshop to be used with LND150:
The source follower is standard but I was wondering if I would need R27 and R29 in the recovery stage? Also is recovery stage output impedance going to be low enough? I guess I will have to determine experimentally the R33/R34 divider for the gain I need and C21 for flat frequency response.
Any comments would be appreciated.
