Hi guys,
I am wondering if any of you have any ideas on this one. I'm out of ideas at the moment as to what is causing this problem.
Amp is from a working band's bass player and is a Silverface Bassman 100. Customer hadn't noticed anything wrong with the amp other than the fuse holder was cracked. So I replaced that and fired it up, only to notice that power tube #3 was glowing red. So I shut it down and tested that tube on my mutual conductance tester and it was almost completely dead. All the tubes were Tung-Sol reissue 5881's and had all been replaced at the same time. Power tube #4 had no cathode current and I replaced a blown screen grid resistor. Ordered a new Tung-Sol reissue 5881 for power tube #3 and replaced it. Power tube #1, #2, and #4 all tested out fine, so after retensioning and cleaning the sockets, I fired everything up again and monitered the amp. Set the bias to around 64% of the max and everything sounded good and worked well. Let it cook for 20 minutes with no problems. Called up the bass player and told him to pick up his amp. So he calls me two days later after a show and amp made it through 5 songs and then the sound got funky and he looked and power tubes #3 and #4 were red plating. He shut it off and I have it again on my bench now. Power tubes #3 and #4 are dead and burned, and power tubes #1 and #2 are in perfect health. With no tubes each socket has bias voltage. The screen voltage makes it across the screen resistors. The plate voltage is on all sockets. The coupling caps from the phase inverter to the power tubes don't leak on either side. The amp had been completely rebuilt several years ago and has mostly new carbon comp resistors, Sprague Atom electrolytics, and Mallory 150 coupling caps. Everything in the bias supply is new too. Previously before the second failure all tubes showed proper current draw and were biased and matched well. No evidence of carbon traces on the sockets. It is only power tube sockets #3 and #4 that have the problem, and they both are on the same side of the output transformer. It measures fine as far as I can tell though. The amp will run happily with no problems for hours with no power tubes in there. Somehow when the tubes are added, the two on that side go out of control. It seems like they are losing bias somehow but I haven't checked that since I got the amp back....sort of reluctant to blow any more tubes until I have an idea of what could be going on.....
I will add that the bass player who owns the amp used the right impedance. He is a professional working musician and has played this particular amp with the same rig for the last 20 years with no problems. I have a feeling the tubes are somehow losing bias, but why is the question. These particular tubes have been in use for 6 months for no problems in this amp...well at least until the recent problems. Whatever is going on, it seems to be sockets 3 and 4 as 1 and 2 have no issues and those two tubes are still working just fine. The sockets are fine...no evidence of arcing....pins are not shorted to the chassis....the amp has about -48v bias at the sockets with no tubes in them the way it is adjusted at the moment. The bias control has been changed by past technicians to a coarse bias adjust and it has enough range and works fine. All of the parts are relatively new in the amp as it was overhauled within the last 5 years. Someone on another forum mentioned the Tube Store recommendation about the Tung-Sol 5881 only being a 400v tube...anyone know if this is the case truly or is someone just going off the old datasheets? New Sensor doesn't really share their specs readily. I may have to call them and ask...but most tubes made these days can handle 400v+ as long as you don't exceed the max dissipation. I doubt New Sensor would be making a tube with such a voltage restriction as that would limit their sales. I would guess the 400v max is someone going off the old datasheets, but I suppose a call to new Sensor wouldn't hurt. Incidentally I did set the bias on this based on the 23 watts max and not the 30 watts max of a 6L6GC. Plste voltage on this amp is about 448v. I can try some other power tubes in it, but the fact that the problem seems localized to one side of the output transformer and not the two tubes on the other, and the fact that whatever is going on killed a brand new tube quickly also makes me think it is something else.
Normally I fix stuff like this myself without any issues, but this one has been perplexing for some reason....I'm stumped as to what to look at next. Anyone have any ideas?
Thanks,
Greg
Thanks,
Greg
