Hi everyone.
This may be a simple question for most of you, or maybe I'm missing a piece of the picture here, but I was hoping for some insight on low wattage designs. I've been studying a few schematics of early amps (champs, princtons, early marshalls, etc), and from what I can tell, the wattage produced is determined by the tubes used in the preamp and power amp. The champ and princton for example are incredibly simple designs with a single preamp and output tube and come out around 5 watts. I understand that at a given wattage, the actual dB output varies a bit due to other design factors such as speaker sensitivity, etc. I've seen a few very low wattage amps out there (1 watt, 1/2 watt, etc), and was wondering how an amp with 1 preamp tube and 1 poweramp tube (like the champ and princton) can be designed to only produce 1/2 a watt. Is it simply a matter of adding the appropriate resistors to the chain, the way a basic attenuator would?
Like I said, I'm sure I'm missing a piece of the puzzle and would appreciate a learning opportunity here
I love the idea of the very low wattage amps like the gilmore jr for example. Just want to understand a bit more before I build one.
thanks,
blueguitar.
thanks,
blueguitar.
