Opinions on aamp design most welcome...!
  • Opinions on aamp design most welcome...!
    tonequester here.'I find myself thinking off my first build more and more. Does anybody have an opinion on doing a "Class A". single ended(2output tubes in parallel) using
    EL-84'sCathode biased ? All relpies greatly appriciated. I don't even know if a kit exists for this, as of yet. Tonequester out, for now, hopefully not out for the count !
    Quote : "I have already learned fron the forum, that he "science' of tone depends more on opinion than the numbers. tonequester.
    It probably depends more on the styles of music you want to use it for than anything else. And we don't have that piece of information. Actually, more than style of music, since everyone has their own sound in their head, it might be better to know things like who's sound you like, how much you want to overdrive it or if you want a master volume/uber gain thing, do you need an effects loop or are you a plug and play guy? Reverb? Trem? Amps do A LOT of things. What do you want your amp to do?
    I could certainly tell you what I would build for myself in a ten watt class A, single ended amp (I can even dress myself and tie my own shoes!). But nobody can tell you what you want. So, since the opening post sort of reads 'What do I want?', you might do better to tell us what you want and ask how to get it.
      Assuming that you are set on a Single Ended design then there are better options than paralleling 2 off EL84. The tube (in my own opinion at least) which is closest to the EL84 sonically is not it's big brother the EL34 as most folk might think but rather the KT88. A single KT88 will give more power than 2 paralleled EL84.
      Cheers,
      Ian
        http://www2.uiah.fi/~jlummaa/two_stroke/ I almost built this amp when I first started. A book I bought years ago explained how to build it, it is parallel single ended and you can use any tubes you want in it and mix and match for different tones.
        Just for trivia Gibson ga-8 are parallel single ended and so are THD bi-valve, but I think that's about the only production ones ones I know of. I always liked the parallel output idea too.
        http://my2strokeamp.blogspot.com/
        Theres tons of two stroke amp resorces on google
          Cheers,
          Ian
          AND it's a simpler build!!!
            Weber's Lauren kit https://taweber.powweb.com/store/kits_weber.htm#Lauren should be able to accommodate various tubes / combos, if additional sockets are fitted and the OT secondary tap used is selected appropriately. 10% off currently!
              Cheers,
              Ian
              I like that idea too. Bet it would sound nicer than paralleled EL84s.
              - Yogi Berra
                One of the problems with parallel SE is finding a suitable output transformer. The Hammond ones are fine at lower power but the impedance is too high to get greater than 10W at low voltage. That knocks out 6V6 and EL84. The big voltage is no problem for 6L6, EL34 or KT88. If you really want to run EL84s, consider two OTs in parallel.
                  How about these Hammonds? Maybe the 125ESE at 2.5k?
                  Hammond Mfg. - Universal - Single Ended - Tube Output Transformers - (125 Series)
                    the evolving amp build................................................... .......?
                    Originally posted by printer2 View Post
                    tonequester here.
                    Thanks to all who replied. I appreciate the advice and the comments equally well. I'll skip around cover it all as best as I can. pdf64, you aren't the first to recommend Weber, and I,m sure they make good kits. however, prior experience with the was enough for me. I waited 3 months for a speaker that I had prepaid for. They ignored many
                    e-mails, and many phone calls(always got voice-mail that promised a reply). Finally I e-mailed them to advise them that I was involving the Postal Authorities. They e-mailed me with the claim that they had not recieved my coorespondence, which was utter B.S. 3 days after my last e-mail, I received my speaker." Nuff Said." Thanks to gingertube for the KT-88 idea. As Chuck H said..."a simpler build". I always appreciate loudthud and printer2's comments and all of ther info that I glean goes into a "journal"
                    that I keep.Someday [I]'ll make the final decision. Until then it's "save,save,save", as in cash. Any which way I go will be a major investment. I've got the poverty level beat, but not by much. Before I forget, Pleased to make your "aquaintance" here JoeM !
                    O.K. Chuck H. In a slightly earlier post you mentioned that perhaps I should give out an example of what I'm trying to accomplish. This is a good idea, so unlike me, I
                    gave it some considerable thought and referres back to some old notes that I had saved concerning the sound that is my "number one". I don't know if it will help. I already know what equiment was used, and pretty much how. The information comes from the (" horses mouths") via video interviews. First, Leslie West of Mountain. The recording of Mississippi Queen was done at the Fillmore. He played a Gibson Les Paul Junior, with patent number pick-up, controls wide open. Marshall amps he had expected to be there were not. Instead, he used a Sunn 100W. Head (P.A.) through a 2, 4x12 cabs.The guitar's control's were maxed. The Sunn's sungle volume was maxed. He played
                    the heaviest picks he could find. No effects were used. The cab was miked into the Fillmores P.A system as well. The second example which has the much the same sound
                    (my opinion), is Cream's recording of Robert Johnson's(pseudo) Crossroads. It was also recorded live at the fiimore. he played a Gibson SG(psychedelic paint) 1963 model
                    with patent number pick-ups, with a hard-tail bridge. The amplification used was 2 JTM 100,1959 lead models, through 2,4x121 cabs. He played both guitar and amps "cranked up". Clapton also miked into the fillmore West's P.A. system. He can't remember whether he used a Dallas Treble Boost or not. He had used one often
                    since his Bluesbreakers days. I like the overdriven sound, but not so far as to create more distortion as these examples. Although both amps were push-pull and rated 100 W., they used different tubes, and completely different circuitry. You might ask why I don't get a Gibson. I have, in the past had 2. They got me no closer than I am now. I am going to completely re-wire the Kramer and put a humbucker in the bridge position. I said that this may well be an impossible dream. I am NOT going to buy or build a 100W. anything to keep in the "cranked" mode. Tone is very subjective, and I will get close with a smaller, less expensive amp(barring a hand built kit for the added experience). It may be Class A or Class Q for all I know at present. If tone were the only consideration, I,d save my money and keep my HT-1R "throw-away). However, from experience, I need at leasst 20W., and 30 would be better.
                    I replaced the nut yesterday, so the acoustic work on the guitar is done. Now I'll re-place all of the circuitry. The only thing left is the amp after that, in maybe 2 months.
                    I hope the info gives someone an easier time in thinking up something to try, although I doubt that it will. I've played many an amp, some "cranked", and i haven't pleased MY ears yet. Thanks to one and all, you're all great people. Here's all the best to you ALL ! tonequester.
                      I did a SE for 2 x 6V6s a couple of years ago - uses EF86 in V1 with Merlin's triode/pentode morph control, feeding a Big Muff tonestack, 10" greenback, and can run a variety of rectifier tubes (for different B+) - Also has a separate bias resistor for running 1 x 6V6, or a 6L6. Schematic attached.
                      Soundbyte links FWIW
                      Me doin' Jimi Page:
                      Super AC4 - Bigg Muff 3.mp3
                      Me doin' other stuff
                      Super AC4 - Big Muff TS.mp3
                      Super AC4 - Big Muff TS 2.mp3
                      Super AC4 - Big Muff 4.mp3
                        Me doin' Jimi Page:
                        tonequester here.
                        Thanks for the schematics tubeswell. I've copied everything down for further study(sound links as well). I really appreciate your interest in my post.
                        If you are Jimi Page fan, you must be a-O.K. in my book. Have a "good 'un". tonequester.
                        Quote : "If you have a good vibrato, you can get away with a lot". Sonny Terry.
                          tonequester here. A point well taken concerning the transformer. If one finds one, I'm sure that one will pay "through the nose". Thanks for your input, which is always quite welcome
                          loudthud. Have a "good 'un". tonequester.
                          Quote ; If a man has common sense, he has all the sense there is". Sam Rayburn.
                            Originally posted by tonequester View Post
                            tonequester here.
                            First, Leslie West of Mountain. The recording of Mississippi Queen was done at the Fillmore. He played a Gibson Les Paul Junior, with patent number pick-up, controls wide open. Marshall amps he had expected to be there were not. Instead, he used a Sunn 100W. Head (P.A.) ...
                            ...I am going to completely re-wire the Kramer and put a humbucker in the bridge position.
                            Whenever I saw LW back then, he had a JR w/P-90s not Humbuckers, seems like the 90s were a big part of his old sound. Usually looked like this-
                            " mountain " - live on beat club - YouTube
                              live on beat club.
                              tonequester here and pleased to "make your aquaintance" Tonewood. Thanks for the great video. The pick-up thing was the sketchiest part of the info that I had gathered.
                              This video did have a brighter "kick" to it, unlike a humbucker. I wish that I could gotten a good look see. I'm taking your word for it though. The rest of what I posted came from West himself, so I'll stand by it. However, I do wonder at times even about the performer's memory on the subject. George Harrison gave several answers over the years as to what the opening chord from "A Hard Days Night". I have a" note for note" Beatles tab book that claims it to be Fadd9, but my ear says "no Way".
                              Thanks for the interest and the informational reply, greatly apperciated. tonequester.
                              Quote ; Knock the "T" out of "Can't". George(Superman)Reeves.
