No your measurements ARE useful, but the devil is in the detail as usual. You describe the screen voltage measurement was at sagged level/conditions. Was the screen current measured under the same sagged conditions?
Multiplying those voltage and current levels give you an upper limit on screen dissipation, but I reckon the real screen power dissipation level will be less due to waveform distortion (and its affect on power factor). Unless you have a specialist power meter, or digital oscilloscope that can do the right maths functions, then the next best thing would be to capture a waveform of the screen voltage and current waveforms somehow when at max output.
