Hi, I am studying the RDH4 and I want to do a design example to verify whether I am doing in correctly. I make up some number to make things easier, but I use the true data of the 6V6GTA for the design.
I am designing a Class A push pull with B+=320V with cathode bias and I run the tube in triode mode. I am using quiescent current of 35mA per tube so it's 70mA total. As the cathode is about +20V above the grounded grid, so I use a 320V supply so I have 300V across the tube. I draw the load line in red from the quiescent point of 300V and 35mA. I choose the second point of the load line at Vg1=0V at 80mA to make sure it stay below the 14W. I might have violate the max power along the line when travel from the quiescent point to the max current. I am too lazy to plot the max power curve, I just assume that I am not violating the power. I show the calculation how I arrive the load impedance RL by using the slope of the load line in red. Being a push pull, I assume half of the primary is 2.625K. So I need an OT of primary of 5.2K or so.
![](http://i48.tinypic.com/e0262h.jpg)
This is an exercise, I don't know enough to optimize for distortion or something. Please give me advice what else I need to look out.
From the graph, Vg1=-22V. I calculate the cathode resistor to drop 22V with 70mA, it turn out to be 314ohm. My question is if I am designing for class AB and if I set the tail current very low ( say 10mA). For -25V, the cathode resistor would have to be 2.5K. But then I will have issue when I put in large signal where one tube will conduct more than the total current of the tail ( larger than 10mA). How can a cathode bias work for class AB?
Thanks
Alan
Thanks
Alan
