Probably a newb question but: Just looking at a Hotcat power supply and the HT is rectified through N4007s then joined between pins 4 and 6 (anodes) of the 5AR4. The HT across the 4-6 junction is switched on with a 100uf cap for solid state supply or off for tube rectifier supply. Having the rectified DC fed across the 5AR4 seems to be bothering me but I guess it has no ill effect on the tube? All it seems to do is give the sag resistance and some voltage drop I suppose. I was expecting the 5AR4 to be taken out of the circuit all together but it stays in circuit.
Was there a question in there?
Are there any issues with rectified HT across the 5AR4 parallel plates?
![Stick Out Tongue](https://music-electronics-forum.com/core/images/smilies/tongue.png)
