I'm currently testing out some solid state relays for their suitability in high impedance circuits, and they've actually performed pretty well. However, there is a little problem where I'm left scratching my head... I A/B tested two identical circuits, where one circuit had solid state relays in parallel across each resistor, with all of the relays being turned off. This has the effect of putting the transfer capacitance of the SSR in parallel with the resistor, which is only something like 20pf in my case.
I was initially disappointed with the high frequency response of the circuit, in that it starting rolling off at only 2kHz in comparison to the reference circuit. I suspected the relays in parallel with the plate resistor and grid leak (the grid leak after the coupling cap). So I removed those and nothing changed. Confused, I also removed the relay across the cathode resistor. Nothing changed. Finally, when I removed the relay across the grid stopper, the scope trace at the output suddenly shot up to be on par with the reference circuit. Tracing my way back to the grid of each triode, I found the voltage to be much lower on the side where the relay was attached. Again, when the relay was removed, the trace went up to meet the reference circuit. I stuck the other relays back in and they didn't seem to affect the frequency response at all until I got up to about 10kHz! I also swapped triode sections with each respective circuit but it was still doing the same thing.
The part that is leaving me puzzled, is why the frequency response drops when you place a capacitive device across the grid stopper. IIRC bogner used capacitors across the grid stopper to increase the HF response, not decrease it! I'm thinking it may be due to some loading effect and it's interaction with my signal generator, AKA, my headphone amplifier and PC, but I have to concoct some sort of buffer to test my theory out... Any suggestions as to why it's doing this would be enlightening
PS, in the schematic just pretend there are relays in parallel with the resistors in either circuit
