Hi All,
A got myself a birthday present in the form of a Tonghui TH2822A LCR meter. These can be had now for under $200 and are very similar indeed to the well known BK Precision 879B. Anyway for a unit in this price range it seemingly packs a lot of punch: L / C / R / Z; secondary parameters / Q / θ / ESR, with 100Hz-10KHz measurement frequencies.
Of course, I immediately set out to measure all of the caps and inductors that come to hand, and quickly came to the conclusion that correctly using these LCR meters is rather more nuanced than it appears at first blush.
One of the first things I checked was an Allen Amps TO-26 output transformer. The OEM is Heyboer, Heyboer part HTS-9483
According to the Allen amps website this is nominally 7000K into 8R or 16R, intended for 2x6V6 in push-pull operation.
What follows is a description of some readings I took, and there are a few things lurking there that I hope the brain trust here can help me figure out.
First of all, I took measurements of the inductance of the primary and secondary impedances with taps open... the first mystery is that the pri/sec inductance ratio doesn't look anything like the 7K:16R impedance ratio suggested by the spec. It's much lower, with about a 336:1 ratio (18.3:1 turns ratio) instead of the 438:1 ratio (20.9:1 turns ratio) I thought I would see. The inductance ratio suggests a transformer that is more like 5.4K primary Z.
Now, this also turned out to be true of the Z measurements I took. The priZ/secZ ratio was about 315:1, again well short of the 438:1 ratio I expected.
However, when I soldered an 8.2R resistor across the 16R tap, I read a Z (at 1KHz test frequency) of 4.130 K.... Normalizing a bit, 4.130K:8.3 = 7.963: 16R, so this last figure suggests an OT that is behaving more like an 8K:16R.
So I have a discrepancy between the ratio suggested by the unloaded inductances and the unloaded impedances with the ratio suggested by measuring the impedance of the primary under load. And neither of these match the nominal specification of the transformer (although I have written to David Allen to confirm that it is not, in fact, supposed to be an 8K pri Z transformer, as this is pretty common for 6V6 amps).
The problem is that I don't have enough experience to know whether this is something that would be anticipated, either because of the way that I'm using the meter, or because I haven't properly accounted for the influence of parasitics, or if the meter is simply reading inductance incorrectly. The meter is calibrated to account for leads, but I don't have a good external standard inductor to check it against.
What do you think? Hopefully somebody that really understands magnetics will chime in.
EDIT: The inductance and impedance ratios measured at 120Hz are also off.. 8.887H pri/34.8mH sec.. so actually even more wonky at about 255:1, suggesting an ~4K pri. Z. These are big errors!
Primary leads: Blue-Red(CT)-Brown
Secondary leads: Black(common) - Green - Yellow
Measurements are from TH2822A at 1KHz, serial mode, except for DCR from an Ideal 61-312 DMM.
DCR:
Brown-Blue: 249.9R
Blue-Red: 130.8R
Brown-Red:118.4R
Black-Yellow: 0.9R*
Black-Yellow: 0.9R*
Green-Yellow: 1.9R*
* DCR measurements in this range should be regarded as approximate only
Primaries, with secondaries open:
Blue-Brown: 7.064H, Q 5.07, 45.28K Z
Brown-Red: 1.7976H, Q 4.755, 11.53K Z
Blue-Red: 1.807H, Q 4.694, 11.58K Z
Secondaries:
Black-Green (8R tap): 10.776mH, Q 2.625, 72.51R Z
Black-Yellow16R tap): 21.041mH, Q 2.634, 143.97R Z
Green-Yellow: 1.957mH, Q 2.684, 13.152R Z
Primaries with secondaries shorted (all three secondary leads soldered together, inductance values reflect leakage inductance):
Blue-Brown: 36.434 mH, Q 0.4208
Blue-Red: 13.396mH
Brown-Red: 10.037 mH
(interestingly if I solder together only the full tap black-yellow secondary leads I get more like 85mH - I don't know why?)
DCR:
Brown-Blue: 249.9R
Blue-Red: 130.8R
Brown-Red:118.4R
Black-Yellow: 0.9R*
Black-Yellow: 0.9R*
Green-Yellow: 1.9R*
Secondaries:
Blue-Red: 13.396mH
