I figured out how to change from the 5E3 interactive volume and tone controls to the normal voltage divider pot arrangement using a four pole toggle switch and a couple of mixing resistors. I figured out the reversing of the pots way back but I never thought to put the mixing resistors in the loop. So for any of you that wanted the stock 5E3 funky control response but would also like to change to the normal Brown circuit. A four pole toggle switch and two mixing resistors, schematic is in the normal position.
