Wurlitzer 206
In that circuit the output capacitor does double duty as the driver stage bootstrap. 100mA shouldn't affect the speaker. You only see this on low cost designs.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostIn that circuit the output capacitor does double duty as the driver stage bootstrap. 100mA shouldn't affect the speaker. You only see this on low cost designs.
The bootstrapped current source has been used since the late 60's and is still used today. On what planet does the amp work "the same without it"?WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostThe bootstrapped current source has been used since the late 60's and is still used today. On what planet does the amp work "the same without it"?
Originally posted by Steve Conner View PostWell, it is a bootstrap. If you disable it, the bottom half of the output stage will clip sooner, so the output power will be reduced.
Also this amp doesn't operate anywhere near power stage clipping -- the weak link in terms of signal size is TR7 and the way its connected to the driver.
Originally posted by woodyc View PostI don't follow why that connection should affect power stage clipping, or why it would only affect the bottom transistor when you have a complementary pair with the same signal on the bases?
Talk about assymmetry.
Or to see it from another point of view: the top half of the wave is fed from a constant current supply: Tr8, while the lower half is not: R7 (200 ohms) .... *but* bootstrapping turns it also into a good imitation of a constant current source, that's what the designer intended.
He saved a somewhat large electrolytic and a power resistor by making the coupling cap (which, by the way, is pitifully small by modern standards) do double duty and allowing for those 100mA through the speaker.
Please don't be harsh with him, 40 years ago this was acceptable.
Originally posted by woodyc View PostAlso this amp doesn't operate anywhere near power stage clipping
If in a bedroom, maybe it won't matter (if he uses 1 watt ) but in a stage, club, or church, etc. it is *not* the same to have 25 clean watts available, as having only 6 clean watts.
Specially in a piano-family keyboard, where distortion is ugly.
Originally posted by woodyc View Post-- the weak link in terms of signal size is TR7 and the way its connected to the driver.
There is not *voltage* gain involved in Tr7's operation, it works as an audio modulated current source for Tr8, which is *the* main voltage gain stage in that amp architecture.
By the way, do you have one of those Wurlitzers?
Love them.Juan Manuel Fahey
Originally posted by J M Fahey View Post...Don't get what you mean. The amp will operate to the volume set by the Musician, according to his needs.
Specially in a piano-family keyboard, where distortion is ugly...
I'll have to think more about your theory of operation of the power amp.
But about the output...
The supply voltage and output transistor ratings are misleading. I have a couple of Wurlitzer amps here, but no complete pianos, so I can't get an exact number on the actual power. But I'd guess that if you banged on a chord continuously with the volume cranked, 2 Watts might be an upper limit? The reason for the low output is that most of these pianos have internal speakers and its very easy to get the reeds feeding back. The 206 uses the same amp board with an 8 Ohm/5W resistor in place of the speaker, but 5W is way more than they needed. Another clip-related thing thats different here is that the reed/hammer mechanism has a soft attack -- there isn't a giant transient at the start of every note like a guitar. The reason I mention all this power stuff is that it may be the reason that you can make changes to the amp (like grounding R7) that make no audible difference.
Here's how I understand it. This amp runs off a single supply. Let's say 24V. So at idle, the output stage emitters sit at 12V. The speaker terminal sits at 0V, so the output capacitor is charged to 12V.
Now let's try reproducing a big negative transient. The emitters go down to maybe 1V. The speaker terminal is forced down to -11V. 11 volts are available for forcing current through R7, whereas if it were connected to ground, there would be less than 1V across it. The result is that the lower output transistor has 11 times more base drive available.
I don't own a Wurlitzer 200, but I have played a few, they sound great!"Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostHere's how I understand it...
I don't know if anybody noticed this, but the way this amp works is really bizarre...
At idle TR9 carries about 100mA and TR10 is off so for small signals TR9 is a single-ended class A amp. (If you check the bias string and max current in TR8, its clear only one output transistor can ever be on.) When TR9 reaches cutoff, TR10 turns on to take over for the cut off peak. This creates an asymmetry which affects the bias of TR7 since the feedback is DC. The inclusion of positive feedback just adds to the intrigue.
P.S. The thing I said earlier about TR7 being the weak link was complete BS -- the only reason you see clipping there is because it's in the feedback loop. Sorry, internet.
The bootstrap definitely gives you more output, But I think the "explanations" above are incorrect. I'm not sure I can explain it any better, but its a really interesting technique so I'll try...
Firstly, all they are doing with the bootstrap is increasing the AC impedance of R7.
This does not mean that the base current in TR10 is impeded. It means that more of the AC current in the bias string will flow through the bases, making the driver much more effective (about 3x in this case.)
While technically the current coming out of TR10 base does go through R7, its just replacing current that is being removed by the driver. So R7 becomes irrelevant AC-wise.
The reason this gives you more power is that without the bootstrap the max ac current in the bias string was just not capable of pushing enough current through the bases -- most of it was going thru R7.
While there is definitely some asymmetry here, it seems like the principal effect of the bootstrap is similar at both bases. So the thing Steve said about only the bottom half clipping, or what Juan said about only the top half being fed by a current source seem incorrect to me.
But maybe I'm just not getting it?
Also if what I'm saying is correct, replacing R7 with a choke should have about the same effect as the bootstrap?
A transistor collector is a current source, meaning current does not depend on voltage applied (in this case it depends on base current only).
Just look at transistor collector current vs collector voltage graphs.
You'll see they are practically horizontal, meaning they don't change with applied voltage; hence, constant current.
This falls out when voltage is so low as to cause transistor saturation, usually 1 or 2 volts, so worst case you "lose" a couple volts.
On the contrary, current through a resistor *does* depend on applied voltage, the so called Ohm's Law.
I guess you can understand and differentiate between such different behaviors I just stated.
In a nutshell: in a transistor, current does NOT depend on applied voltage, hence constant current; on a resistor, current DOES depend on applied voltage.
If you do not get this, please re read it until you do.
No explanation will make sense to you otherwise.
We must agree on certain basic premises or it's like speaking different languages; words will be heard, but convey no meaning.
Thanks.Juan Manuel Fahey
Juan, the point of disagreement has nothing to do with whether or not a collector is a current source. Its this...
Originally posted by J M Fahey View Post...the top half of the wave is fed from a constant current supply: Tr8, while the lower half is not: R7 (200 ohms)...
