I am adding a 5v relay switch to a peavey amp. The taps I am using are 32Vac which after a bridge rect. will be about 45v. I have a 7805 but I was wondering if dropping 40v would generate too much heat on the 7805? Also what value caps should I use? Should I drop some voltage first then regulate or just use a heatsink?
Here is a pic of what I am going to build.
http://www.eleccircuit.com/wp-conten...y-ic-78s05.gif
