Originally posted by tubeswell
View Post
LTPI ?
Originally posted by catnine View PostThe build I have after the 22K node resister is 312VDC which I assume is the HT fro V1 . One V1 the 12ay7 I have a plate of 151.5 VDC and a cathode of 2.37 VDC .Building a better world (one tube amp at a time)
Originally posted by tubeswell View PostNo matter. With the HT at 312 and with RK = 2k7, it would still be biased in about the mid point of the load lineLast edited by catnine; 12-18-2012, 04:21 AM.
Originally posted by catnine View Posttubeswell : I don't quite understand . Since the 5E3 uses a 820 ohm bias resister for both triodes and I used a 1.5K ohm for one triode using 2.7K is almost three times the resistance of the original 820 ohm . You say I will get more of a midpoint bias if I use the 2.7K P-P meaning peak to peak?
Originally posted by catnine View PostAnd if I do this I will have more clean headroom ?
Originally posted by catnine View PostSo the 1.5 K will cause the 12ay7 to clip sooner?
Originally posted by catnine View Postdoes this have something to do with not using the plate and grid of one triode i.e.: no VDC on one plate and no signal on one grid = no current draw ?Building a better world (one tube amp at a time)
Originally posted by tubeswell View PostWith a 12AY7 at HT = 315 volts with a 100k plate load - yes.
In terms of what you have feed to the grid - yes. The more that the bias point is in the 'middle' of the grid curves on the load line, the more optimally biased the stage will be in terms of clean headroom.
With a HT = 315V and a 100k plate load - yes - if the voltage swing at the grid is sufficienty large enough to cause the stage to go into grid current limiting. On the example shown with HT = 365, the bias point with Rk = 1k5 is about -2.8V. (This comes down to about -2.5V with HT = 315V). This is closer to the Vg = 0V end of the load line than if you chose a Rk = 2k7, therefore the stage would go into grid current limiting sooner (if the swing at the grid was large enough). These are theoretical load line and bias points based on an 'idealised' 12AY7 set of grid curves. Real world operating conditions may differ slightly depending on the actual tube.
Each triode in a dual triode is separate from the other, unless you wire the socket pins in parallel.
Originally posted by catnine View PostThis means that the 5E3 was not biased properly .Building a better world (one tube amp at a time)
I must say that I do not have the knowlegde to say why the 12ay7 should have more headroom than a 12ax7 in V1 if the input gain was compensated for the difference, but on some amp balancing the gain between stages are important for best clean headroom.
But all clips I hear of 5e3's with a 12ax7 in V1 seem grainy and not so tonally pleasent as the ones with a 12ay7 in V1. Maybe the bias point is of with a 12ax7 in that position. But a Dearmond R15 has a 12ax7 in V1 with similar voltages, bypass cap and resistor, but the bypass cap on V2 (12ax7) is omitted and that balances things out. Also the Dearmond has 350K volume pots in relation to the 5e3's 1M pots. The Dearmond uses 0.047µf coupling caps but so did the Fender 5C3 and 5D3.
So the Dearmond R15 has a higher gain first stage and a lower gain second stage (total max gain factor of 92)
The 5e3 has a lower gain first stage but a higher gain second stage (total max gain factor of 93.5)
The two amps are fairly similar but the Dearmond is a bit stronger with larger transformers, smaller coupling caps and a large 40µf main filter cap to keep the bass more tight. Suppose to take humbuckers better than a stock 5e3.
Leonc build a clone of the Dearmond R15t, with the only exception of using 500k pots as the 350K (volume pots) and 650K (tone pot) are hard to come by. With a loud eminence swamp thing it is a great loud amp... check Youtube
Originally posted by barfoden View Post... why the 12ay7 should have more headroom than a 12ax7 in V1 if the input gain was compensated for the difference, but on some amp balancing the gain between stages are important for best clean headroom.
But all clips I hear of 5e3's with a 12ax7 in V1 seem grainy and not so tonally pleasent as the ones with a 12ay7 in V1...
The answer lies in the transconductance and plate resistance characteristics of both types of tubes:
Could you please explain the relation ?
Correct me if I'm wrong : what I have always thought is that the higher the transconductance the faster a tube goes into distortion when given too high a signal.
Maybe I'm completely wrong !
Originally posted by Alf View PostThat's info I've been trying to get for quite some time !
If I would generalize, I'd say that mu is related to the ability of the tube to be overdriven in a specific circuit. Note that jazzbo8 points out that with these two parameters (mu and gm), the tube's resistance also changes. When tubes are swapped with different models, the designer's assumptions about the circuit may be totally thrown out of whack, so headroom and bias may need to be calculated and adjusted to achieve desired performance.
Again to generalize, it's OK to swap any of these tubes and observe the changes to the circuit's behavior. Note the tube's voltages, plot the bias point on a grid-curve chart, and see what has happened to headroom, etc.If it still won't get loud enough, it's probably broken. - Steve Conner
barfoden's question was why the 12ay7 should have more headroom than a 12ax7
The answer is that the transconductance and plate resistance determine the tube's amplification factor. (jazbo8 explained how gm and rp get mu).
All other things being equal, if you change the plate resistance and/or transconductance, you will change the possible gain. A 12AY7 has a lot lower plate resistance than a 12AX7, even though the transconductance of both types is similar.Building a better world (one tube amp at a time)
