Hello,
I have a SF Showman/Twin Reverb OT that I'd like to use to make a small bass (single channel 1x12" ~50W) combo. As I understand, if I have an amp with four output tubes and I pull two, I also want to halve the speaker load to keep the matched ratio? Since this is basically what I am doing (using a 4x6L6 OT 4-ohm sec. w. 2 6L6s), I would want to run this at a 2ohm load, which would be rather impractical since 2ohm speakers are rare and don't want to use 2 speakers. Is that correct? I'd rather not blow up this transformer doing something silly, but if I can use it, it was free... Are there other output tubes that might provide a better match for this OT in a pair? I'm still learning the basic concepts in amp-math, impedance matching, what specs apply to what application. What spec would I check as I surf other output tubes? I'd like to do some research and learn some basic concepts. I'm comfortable with 6CA7, KT66, the usual suspects. 6AR6 might be attractive & cheap... others? Nothing TOO weird. :P
Thanks in advance,
Justin
Thanks in advance,
Justin
