This is build I did of a SF Champ no vribrato. I see the bypass cap on the second gain stage pin 8 of V1 cathode bias is 2 uf on the SF champ . The SF Vibro Champ has a 10 uf bypass cap . So I used alligator clips and two jumper leads to clip the pos side of the 25 uf cap to the Pos side of the 2uf cap . Then jumpered the neg side of the 25uf to the switch and then back to the same 2uf ground before the 46 ohm resister to ground after the 1.5K bias resister.
It seems to be part of the NFB loop but the bypass caps only share the 46ohm resister to ground so I'm not sure if it is in the NFB loop . I heard a more focued bass and some mids . I wired it in the circuit . It works , the only issue is I get a very slight spilt second pop when the 25uf cap is switched into the circuit.
Is the slight pop normal? I was just trying to get a bit more bottom end and this seemed to get me near there. here is the champ schem .
