Just curious about a concept that I haven't found much about in the various tube-preamp design books.
Here are two scope traces, showing the signal at the grid of the DCCF stage (i.e. the plate of the gain stage that drives the CF) right before the tone stack, superimposed on the signal at the output of the CF (top of the 100k cathode R). The output of the CF has this triangular shape on the leading-edge of the negative-going half, which looks like slew-rate limiting, but I would assume isn't really. What causes this, and what is it called? Why would the CF stage, with unity gain, "break up" before the preceding gain stage?
This is a typical pre-EQ 12AX7 DCCF with the 100k/820R unbypassed gain stage into the CF with a 100k cathode resistor. It's driving a normal Fender-style tone stack with a 1-meg MV. B+ here is about 340V.
1kHz:
100Hz:
1kHz:
100Hz:
