I have a vague idea of how I might be able to safely direct couple an output stage, do you guys think it would work ok? By using a dual rail power supply and the primary of a output transformer as a choke, the dc voltage of the bias for the following stage could be kept almost constant. For the supply, it is a center tapped power transformer with bridge rectifier and the center tap is the middle rail. Thoughts? Here is a basic idea:
Thanks!
Thanks!
