There was a similar thread some time ago which I cannot find right now. I build a 50W plexi that sounds really great. But I would like to test if its possible to bring the volume (clean headroom) down. (I know there might be other possibilites like MV which could make more sense)
My PT has 325V which is OK. When I run my 8 Ohm speaker with the 16 Ohm OT setting the tubes should see 6400 Ohms which is also OK for 6v6. I have to change a little thing about the bias and the grid resistors as described here.
http://mhuss.com/Plexi6V6/Plexi6V6c.gif
Very minor changes actually.
Now to the question If the OT stays the same (50W) will this give me the same sound as if I would switch to a 20W OT (everything else being the same). In the thread back than someone said it would not matter cause the distortion comes from the tubes anyway. Probably the bass will be a bit more tight with the bigger iron. But other than that would the amp have around 20W when changing to 6V6?
