When I first tried my plexi with 50+50 Filter caps I had almost no hum. Now I switched to 32+32 and like the feeling with those caps a lot better. But I do get a loud 50Hz hum (at least it sounds like 50Hz)
This hum is there with no guitar plugged in, no PI tube and does not get louder when I turn up the volume. So in a band situation you wouldn't really notice. But still it is not very nice.
I tried to move wires around and tried different grounding points. But nothing helps. If I don't find a solution I have to go back to 50+50 filtering I think. Maybe somebody has an idea how to solve this. I know the earlier Marshalls all used 32u+32u caps or even lower. So this should actually work. Also could be the caps are bad (they are brand new). Is there a way to measure this?
I used this layout. http://www.ceriatone.com/images/layo...exi50-Lead.jpg
