I’m doing my best to learn about guitar amp theory and design...been reading both O’Connor and articles by Aiken. The technical information I’m finding seems to be pretty solid (as far as I know), but I’m having a hard time connecting the dots...I can’t seem to find the little nuggets of insight that explain what it all means in the big picture (with regard to playing guitar).
For example: On setting the bias point for a typical gain stage Aiken says, “the plate resistor is chosen first, typically around twice the value of the internal plate resistance of the tube for most linear operation, although higher values can be used for more gain and output voltage swing.” I looked up the plate resistance of a JJ ECC83, and saw it was 47kΩ, which is indeed about half of the 100k-value Rp one typically sees in a Fender/Marshall type preamp.
So here’s my questions for anyone who might be able to help me connect the dots: What does linearity mean in the big picture? What does it mean with respect to guitar preamp performance? My next question: given Ohm’s law, increasing the Rp value increases the voltage swing given the same conditions...so what might larger voltage swings mean for me as guitar player?
If anyone can point me toward a source(s) of literature that explains amp theory with the big picture in mind, I would really appreciate it.
Thanks,
Tim
PS – I realize there is a lot to learn/know about amps, and it can’t all possibly be published in one place. So this is not intended as a criticism on O’Connor or Aiken...I personally just don’t seem to be learning well from these particular sources.
Thanks,
Tim
