Hello folks,
I'm thinking about purchasing a new 50w (boutique) amp head that has two output jacks at 8/16 ohm, but after researching things here and elsewhere, I'm concerned about whether I can safely run two 8-ohm cabs with it? Can anybody help with this question?
As I understand it (via Ohm's law), running two 8-ohm cabs connected to a pair of output jacks listed as 8/16 in this way would amount to running at 4-ohms, and some say that although doing so yields less power, it is perfectly safe, because its "lesser" (4-ohms), not "greater" (16-ohms) impedance, but I'd like to be "certain" of this assertion. I own (and can use, if necessary) a decent attenuator with impedance control for just such applications, but I don't really NEED an attenuator in this application, so if possible, I'd like NOT to use it strictly for its impedance regulation function.
Can anyone shed some light on this subject for me? Can I plug my two 8-ohm cabs into the two 8/16 output jacks on this amp head and run at 4-ohms without any fear?
Thank you!
Thank you!
