Having trouble with the new Photobucket webpage...but suffice it to say I am using a very narrow chassis. Not much room from the faceplate to the back-plate.
So I have had to mount some things (dual bias pots for one) under the board. I would hate to spend a lot of time wiring up the tag board, and then find I have a problem that requires removing the board.
So finally.....is there any "problem" with putting power to my build without the tubes and board.?
Tube sockets are in.
The heaters are wired.
OT CT is wired, and so are the OT Primary.
The negative bias circuit is wired, but not to the grids.
Thank You
http://s111.photobucket.com/user/zzm...ry/proto%206k6
Thank You
