I'm trying to add a relay to switch between two 100K master volumes on a concentric pot. They share ground. I'm running it off a -15VDC supply, 1n4005 and cap across the relay coil.
I couldn't get it to STFU in terms of the pop when the switch was made, and it was much louder with any signal than without. Used various caps across the switch, which helped a tiny amount but not much. Since I'm switching two pots that share a ground, everything should be ground referenced through the pot. The inputs will see 100k to ground, the wipers (much) less. Not sure why the popping noise on this, I've done plenty of switching before and never had an issue as long any caps involved had a ground reference and signals had some reference to each other through a large resistance. Here that should all be taken care of by the fact that nothing is ever floating and there are no caps involved.
So since I couldn't figure that one out, I tried switching using a transistor. Tried it on the downside of the relay between the coil and ground, and also between the -15v supply and the coil. The problem I seem to be having there is with getting the transistor to saturate correctly, because even when the base is lifted from ground there is a large voltage drop across the coil or across the supply, enough to keep the coil charged in fact (release voltage seems to be very low on these 12v relays, on the order of a couple volts). Also, iirc there should be a resistor between the base and ground, but no matter what size resistor I try, it leaves a large enough drop across the coil to charge it and the switching doesn't work. If I ground the base directly it works, but there is a pop that is as least as loud as not using the transistor to switch.
Tried a couple different 12V relays, a couple difference little NPNs, same results.
Any ideas? Should I ditch the transistor switching anyway since it doesn't seem to be any more quiet? Any ideas why the loud pop wont go away even with everything ground referenced and caps across the diode and switch? If I keep the transistor switching, what is the proper way to saturate it so that when the base is lifted from ground there is no large drop across the relay coil? The formulas that I was using don't even look close to right in terms of the results. For reference, the coil uses 150mW (at 12V that's 12.5ma), min HFE on the transistor is 300 on the data sheet.
