I can't think of a good way to test high voltage electros for polarity that's guaranteed not to harm it. Maybe some kind of pulsed voltage-current test. The discharge curve timing and oscillator sensitivity tricks might work. I'll have to go look.
The problem is that the same current you'd sense for "oops, conducts that way!" is eating away at the insulating oxide while it flows. On a new, good cap, that might re-form in the weak spots that are conducting current to do the test. Limiting the current limits the damage, so the low-current ways like discharge curve timing and oscillator sensitivity (which ...have... to work by the varying capacitance and resistance of the thing while conducting) will do less damage to be repaired or ignored.
Enzo has the right idea: figure it out from the circuit itself. There's nearly always a diode somewhere making a great polarity indicator for you. It's just sometimes tough to work your way back to the diode.
I have seen some few of these kinds of caps. "Can com pos" means "can common positive".
