output transformer impedence matching
  • output transformer impedence matching
    When matching an OT to output tubes, how close is good enough? Example, the RCA Receiving Tube Manual shows the Effective Load Resistance for a pair of 6L6s in AB push-pull mode as 5.6K ohms. Looking at a couple of transformer manufacturers catalogs, I see 30W 5K and 6.6K OTs, but no 5.6K ohm. Why not, since the 6L6 is a very popular amp tube? I recently bought a 6.6K ohm 30W at the recommendation of an engineer at Mag Comps for a 6L6 project. Why not the 5K, since it's closer in value?
    Or am I not doing this right?
    Randall,
    See this very good lesson on transformers from Jensen. http://www.jensen-transformers.com/a...%20Chapter.pdf
    The tube-seen impedance of your transformer is only valid for a speaker load of nominally 8 ohms. Your transformer may have a variety of speaker loads such as 4 ohms or 16 ohms. Nominally means the rated impedance but this will vary over the audio spectrum. What you are seeking is for the 8 ohm speaker to look like a value close to what the tubes impedance likes to see for the maximum power transfer. At 6.6K the transformer sees a turns ratio of 28.72 (6600 divided by 8 equals 825; take the square root of 825 to be 28.72). Your speaker changes impedance at different frequencies and it will reflect back to the tube by the real speaker impedance, at a particular frequency, times the transformer turns ratio squared. Don't worry too much about the exact match; just get a transformer with enough iron to put out enough power at the lowest frequency you desire.
    Try to obtain a speaker with a higher sensitivity (more effective magnetic structure) as it will put out more sound per watt of applied power.
    I hope this helps.
    Joseph Rogowski
      I think I follow this, but is there a typo in parenthesis?
        Yes, of course he meant to say square root of 825, not 625.
          Where did the Ra-a of 5.6k come from? The RCA datasheet I have shows Ra-a of 6.6k, which matches up well with the maximum output and minimum distortion chart I posted recently on another thread.
          http://music-electronics-forum.com/a...on-vs-load.gif
            Also worth mentioning, the optimum plate impedance varies with operating conditions i.e bias point, plate voltage and screen voltage. In general the actual value is not that critical.
              The data that Jazbo8 posted above is from the older RCA data sheet for the 6L6 {metal}, 6L6G and 6L6GB. The newer RCA data sheet for the 6L6GC does indeed show that for the GC version only you can get 55W with 5.6K Raa, B+ 450V, screen supply 400V. There was a change in the maximum ratings for the GC version, higher B+ and plate dissipation.
                Here's a dumb question. Is the rated input impedance of an OT across each coil (i.e., from the tube plate to B+), or across the two coils connected in series?
                  That's not a dumb question at all, and I await an answer as well.
                    Good catch, had to get a copy of the 6L6GC datasheet.
                    Ra-a is plate-to-plate or the impedance across the whole primary winding.
                    Randall - since you already bought the 6.6k, 30W transformer the chart I posted is still applicable, the Ra-a=5.6k is intended for higher operating voltages (Plate=450V, Screen=400V) and higher power output (55W), which your transformer is not rated for.
                        It is indeed across the whole winding. And what's more, the impedance from either end to the centre tap is not half of the end-to-end value, it's one quarter. One of the great mysteries of transformers
                          Makes sense, thanks for all the good advice.
