Okay, so I have no idea why I'm struggling with this so much, but I'm working with an OT that doesn't exactly match up with my power tubes.
The OT in question is from a Marshall dal-401, which is designed for 4xel84's. I couldn't find out the specifics on it, but I'm assuming its roughly 4000ohm primary.
The amp I'm using this in is 2x6K6 at 285v with 400ohm shared cathode resistor, which according to the data sheet means I'm at 12000ohm.
So if I'm using the 8 ohm secondary tap, and hook up 12k to the primary side of the OT which is expecting 4k, then I would need to hook up a 24ohm load to that 8ohm tap keep the impedances matched. Correct?
If I run a 16ohm load on that 8ohm(24ohm) tap, then my primary side would see roughly 8k.. Does this seem right?
Is that a reasonable mismatch?
